Results 1 to 10 of 10
Thread: How to unlock klicktel 440
    kaffer is offline Private
    Sep 2011
    Hi I have a klicktel 440 navigator, the OS is Win ce 4.2. been trying all the things mentioned in the thread to unlock it. Since there are no more updates for maps I would like to use tomtom or something....please help..
    gyany is offline Second Lieutenant
    Mar 2012
    A, A
    340
    Re: How to unlock klicktel 440
    kaffer Make a backup of the internal memory and post it here(no maps).I will try to help you.
    Sep 2011
    On the SD card I have 2 folders, The first folder name is 2577 and inside is a autorun file, the second folder is name KTnavigator inside this one are mostly drivers and another autorun file and a ktnavigator exe. When I start the navi with the chip in.. and scroll down to system, I see files that I don't see on the SD card...which one should I post??
    Mar 2012
    A, A
    340
    kaffer post what you have in your device and on sdcard----without maps
    Sep 2011
    Hope this is what you need
    Mar 2012
    A, A
    340
    kaffer To be sure of success, i need a backup of the internal memory.......If you can not do that!!!!???? I'm sorry.
    Sep 2011
    Hello
    I deleted the map folder it was inside the kTNavigator folder named "data".
    Thanks in advance.....
    Attached Files Attached Files
    Mar 2012
    A, A
    340
    kaffer Copy on another sdcard formatted FAT32 , not the original, two folders 2577 and kTNavigator.. Probe and hope it works...Ciao GirlShare - Download sdcard.zip
    Sep 2011
    Thanks, but when I click that link for sdcard zip it send me to the file but when I click download it redirects me to another site. do you have another link??
    Mar 2012
    A, A
    340
    Kaffer Here is >>>>> girlshare.ro_sdcard.zip
