Results 1 to 7 of 7
Thread: who help me to unlock the KNA-G430TH (garmin GVN-52)
    patsak is offline Lance Corporal
    Smile who help me to unlock the KNA-G430TH (garmin GVN-52)
    Now..My map is thailand city navigator V 7.0 (TCN V.7).Now it devolov to version 9
    Everybody have the map and Unlock it. please helps to divide for me.
    I have set up it appeareds my car.Is Kenwood DDX8639 2DIN and KNA-G430th.
    thank you very much for help.
    peters is offline Corporal
    25
    Re: who help me to unlock the KNA-G430TH (garmin GVN-52)
    I did not have such a device like you have , what I have are Nuvii 660 ,760 and I did up date my map recently , try open your unit , find the unit ID and try new map with JM
    if you have garmin device you must change your map not unlock device!
    I have tried already.My GPS unit box is Kenwood OEM by garmin.I set up the thailand street map gets down it tells a map locks.
    I get the telephone goes to ask at, ESRI (Garmin in thailand). They tell me that , send , GPS Unit box with SD card go to kenwood service center only.And I must pay 1,500 Bath for a maps.I think that the thailand city navigator make for kenwood only.
    I think them lock at sd card and maps because I copy old map from sd card to new sd card It show the map is lock .
    suppose. If I want to go to other country. what can I do.
    Now I useTCN V7.0 I want upgrade to V9.
    my Unit ID is 3268790104 the maps is Thailand city navigator V7.0
    try to get the "SD card ID" and unlock the map using SD ID not unit ID. Nuvi 265 can give SD ID.
    Easy Easy I just unlock my new map with JVC for my GVN-53 you just find the garmin unlocker (not the keygen) to unlock the map I try to contact kenwood but really no help and waste of time
    PS. Just install less than a week and still found no problem or you can PM/message me for help
    Thank you for Everybody. Now I can set up my map tsm 9.0.
