Results 1 to 10 of 15
Thread: Sd card not detected
    willowgate is offline Corporal
    16
    Question Sd card not detected
    I unlocked my WinCE 5 GPS. But now I have a problem. When I insert a SD/MMC card in the drive the card is not detected. I can't acces to the SD Card.
    Any suggession ?
    Regards,
    Willow
    NRT's Avatar
    NRT
    NRT is offline Command Sergeant Major
    206
    Re: Sd card not detected
    Quote Originally Posted by willowgate View Post
    Any suggession ?
    Regards,
    Willow
    What is the name of the gps unit and the unlock program used?
    16
    My GPS model is a Global Tech GPS903. See the link: I modified the registry to launch explorer.exe. Maybe I corrupted some registry key...
    - Do you know a method to reinstall the SD Card driver ?
    - Can I reset the registry to the factory default ?
    - Any other suggestions ?
    Best Regards,
    Willow
    madmar57 is offline Corporal
    26
    Did you try an "ordinary" sd card ? Sometimes these new ones are not compatible with all devices.
    16
    The card works fine before the registry modification. Now the SDMMC doesn't appear in Windows CE.
    Regards,
    Willow
    Oct 2011
    Hi
    I also have problem with my GPS (actually belong to my friend)
    I remove the SD card and use card reader to copy the memory into my computer.
    After finish copy, I put back into GPS device.
    Suddenly, the device cannot detect the SD memory. I press GPS icon and nothing happen.
    Pls help, don know what to explain to my friend..
    Sd card not detected-gps.jpgSd card not detected-not-detect.jpgSd card not detected-system-info.jpg
    959
    Quote Originally Posted by east85 View Post
    Hi
    Click image for larger version.
ID:	4859Click image for larger version.
Name:	Not detect.jpg
ID:	4860Click image for larger version.
    If you don't properly remove the sd card from your windows pc, you stand the risk of corrupting it. Here is a video that shows the safe way of removing a sd card from a windows xp pc. If you have corrupted the sdcard, sometimes it can be fixed with a program like gparted(for advanced users only), but usually the data is lost, and the best you can do is to reformat the sd card with a industry standard sd card re-formatter, and rebuild the sd-card the hard way.
    mrchaq is offline Private
    Mar 2012
    hi..
    i have double din player..got built in navigation..got 2 slots of sd card..1 slot wrote there sd card n other 1 wrote there map card...my problem is when i insert the card with igo primo to the map card slot, it's not detected, when i touch the navi icon on screen nothing happen except the beep..nothing problem with the card coz it's detected in other 1 slot..please anybody help..thanks..
    959
    Quote Originally Posted by mrchaq View Post
    hi..
    Did it ever work with igo_primo?
    Mar 2012
    Quote Originally Posted by dohcacr View Post
    i got read once in this forum said its work with chinese dvd player or something like that..
