Results 1 to 8 of 8
  • 1 Post By dohcacr
Thread: I need help unlock binatone carrera x430
    marcy_rody is offline Private
    Hi guys, I need some help for my BINATONE CARRERA X 430.
    I want to install a unlock software I ve done before for Navman witch was very easy but with this one is a big challenge .
    I delete all files apart windows folder and still open the same like nothing happen.
    I think the navigation files are in windows folder .I am afraid to touch them
    Please let me know how to do if any one know .I try to use Miopocket 3 there is instructions but dosent same to work MAY BE I DONT INSTALL THE RIGHT FILES.Please give me a program to UNLOCK my BINATONE CARERRA X430
    It has a win ce 5.0
    Re: I need help unlock binatone carrera x430
    Please no one know ?
    i have just done a binatone x350 put tomtom on it
    Hi can u tell me how todo please
    959
    Miopocket has instructions for Biantone GPS's in the MioPocket_Readme.txt file.
    Miopocket v68 Download
    Renegade01 likes this.
    Sorry gays after months of searching I did it so >
    Hi is simple just take a software of TT 7.910 and install on a sd card all files must be in one folder .So if the files wehen you unzip on SD card are all in a folder name Navigation leave them there and rename the folder MobileNavigator exacly like I write here.Than go in this folder where is the TT files and you need to rename same MobileNavigator the executable file witch is the one with TOMTOM logo ,so rename that MobileNavigator.Than you take the new map 865.3259 from here Download WE1GB.part1.rar for free on Filesonic.com
    Download WE1GB.part2.rar for free on Filesonic.com
    Download WE1GB.part3.rar for free on Filesonic.com
    ok after you downland the map instal the map in root of SD card but not in MobileNavigator folder leave separate .Insert the sd in sat nav and click on navigation buton to start TT will show you on screen not map found .You need to download easy tools to unlock the map .Connect the sat nav by usb to PC ond go in SD root there youu will find a file name ttnavigator copy that on descktop and open with notepad .There you have to find the serial for your sat nav will be like this <DeviceUniqueID= AB2SW9JQBE you need this code to insert when easy tools will ask you .copy only the AB2SW9JQBE.
    Than open on sd card the map folder there you need to copy a file name United_Kingdom_and_Republic_of_Ireland-298.meta .this UK map is example can be Europe etc .Open now easy tools and the file United_Kingdom_and_Republic_of_Ireland-298.meta paste in a folder name insert_meta_from_Map_here. paste the file there and go back in easy tools click on RunMeforDCT and press 1 enter than again 1 enter than will ask you to insert that code from descktop AB2SW9JQBE in your case will be different .and press enter .close that program and open again easytools go in folder insert meta from map and copy the 2 files will find in .Go to your sat nav in sd card open the map folder and Paste this 2 files there ..If you follow this steps will work sure .I have the same problem before but no one want to explain so PLEASE HELP OTHER MEMBERS YOU HERE NOT ONLY TO TAKE IDEAS ALSO TO HELP OTHER MEMBERS .CHEERS
    Aug 2014
    is it still working?
    Sep 2014
    hello,
    I am sorry to reply in here but why i can't start new post ? please i have this double din korean device and i need to know if there is any way to unlock it its run windows not sure what version device name REXTA REX-6500 please help .
    thanks
