  • 1 Post By dohcacr
Thread: Pls help unlock becker crocodile z100
    Hi, i will install to crocodil iGO8 and dont me.
    Please help me.
    959
    Re: Pls help unlock becker crocodile z100
    Miopocket has instructions for Becker GPS's in the MioPocket_Readme.txt file.
    Miopocket v68 Download
    teoderik likes this.
    Mar 2013
    Hello guys! I have a Becker Z100 too, and I would like to unlock it with MIOpocket, because the original navigation system became obsolete, and upgrading is really expensive.
    I was able tu run MIOpocket from the internal memory, but now, I've inserted an SD, ant copied it, to make it autorun, like in the readme.txt. The only issue is, that the GPS cannot see the microSD... 256MB NOKIA, just for testing. I don't understand...
    When I open windows explorer, there is no external storage, only My flash disk. What can I do? I copied to sd with the navigation, on windows 7, so the microSD and the system's reader works, but no mount point...
    Any ideas?
    BTW, how do I start a new thread, I cannot find it.
    Mar 2013
    The microSD was corrupted, that was the all problem...
    Anyway, a REALLY IMPORTANT question. What is the biggest microSD, that a Becker GPS can handle? I would like to use 4GB.
    Also I see that currently, under 10 posts I can't open a thread...
    Please answer!
