nimanz okay. i download it.I hope that in 30 minutes to solve....in Resident Flash you have other folders?>>>>>>If you can, make a printscreen with the contents Resident Flash
nimanz ----in computer clik Start\clik Computer\clik Organize\clik Folder and search option\clik View\ clik Show hidden files,folders, and drivers......these settings after you connect the device to your computer and see if it has other folders
I've a question :
Is it possible to install blew patch, if the GPS would unlock ?
Visual GPS
Because this is for another GPS (Mio devices) and I think my GPS has stronger hardware than Mio GPS, both of them have Win CE 6.0, 480x272 1 GB Ram and almost same features. based on my review, Visual GPS is almost complete patch that has many Navigator softwares and useful advantages.
Here is all of them :
I think in the file that I'd uploaded, all of them are there.
no.because I see executables on your device..>>>the device must also be NDrive \ Aplications
yes.but must be unlocked.Be identified executable program navigation
nimanz create a file with notepad that says what you want....file names it >>> YFGo2CE.bld insert the card into the device and start....possible to enter wince
