Thread: MEDION e4230 & similar stuck at red medion screen unlock
    drboka's Avatar
    drboka is offline Corporal
    Serbia
    15
    Copy to your sd card ANY .exe file and rename it to GOCE.exe and it will load. The rest is up to you...
    <a href=http://www.merkurgps.webs.com/ target=_blank>http://www.merkurgps.webs.com/</a>
    Re: MEDION e4230 & similar stuck at red medion screen unlock
    hy,help me with this,i have medion e3212 ,i copyed .exe on sd and renamed to GoCE but when reset device its show me windows explorer for 3 seconds then run medion menu,i try to put igo 8....tanks in advance
    sunshine1 is offline Private
    I replace MNAVDCE.EXE from /navigation/ folder with a script redirecting to my igo8 folder. u can try it on your own risk
