Thread: How to Unlock a Clarion N.I.C.E. p200 gps
    Beartraxx33's Avatar
    Beartraxx33 is offline Sergeant First Class
    Ottawa, Canada
    117
    19
    Exclamation How to Unlock a Clarion N.I.C.E. p200 gps
    Is there a way to unlock this unit. I am so frustrated right now. I even unhidden folders and can't get anywhere.....
    HEEEEEEEEEEEEEEEELLLLLLLLLLLLLLLPPPPPPPPPPPPPPPPP~ ~~~~
    959
    Re: How to Unlock a Clarion N.I.C.E. p200 gps
    What have you learned about how the GPS loads the native nav software?
    Ottawa, Canada
    117
    19
    it loads a menu screen with navigation icon, videos icon, music icon, games icon. the thing is that there are no .txt files to config a path.
    959
    The GPS loads an executable file What is it?
    That information is in the registry under HKEY_LOCAL_MACHINE\Init. Should be about 5 or 6 different files that are started.
    Keep in mind that if you modify the registry, and you don't know what your doing, your probably only seconds away from making your GPS useless.
    Ottawa, Canada
    117
    19
    there are no way of knowing. it doese not even register in the registry beside being a hdd. no files visible even uhidden files. there is gotta be a way to gain access to the inner flash ram to see what and how it loads.
