Results 1 to 10 of 16
Thread: Eonon D1303 with G3001 GPS receiver
    hydekyll is offline Private
    Oct 2011
    Hi, I'm new to GPS
    I've recently got a 1-Din Headunit bundled together with a GPS receiver
    Eonon G1303 | Car GPS | Car DVD GPS | 1 Din Car GPS DVD
    I've installed in perfectly into my car.
    The problem I have is this, When I put in my SD card into the GPS receive it will say on a screen which says 'Car Navigation System' and freeze there
    There is no way for me to choose path of the GPS software I have on my SD card
    I have also followed instructions from Eonon, they kept asking to choose path but I cant
    Any experts/gurus that can help me to understand is it the GPS's issue or my issue?
    I just wanted to know if there are such thing as autorun GPS software without choosing the *.exe files?
    I suppose Eonon will be considered china brand GPS
    I also tried to the Mio Device unlock, but it doesnt work. I've also tested on both SD card slot (on the headunit and GPS card slot) both doesnt do anything
    Please advise me
    3,132
    223
    Re: Eonon D1303 with G3001 GPS receiver
    Autorun will kill your device.
    What is the original software that comes with unit.
    Or it comes empty without any software.
    Any original SD card / sdmmc that comes with your headunit.
    What the CE Version and ram support
    Hope it was not MIPS system - then you have problem looking for software.
    My only advice never install any unlocks in China GPS units.
    Oct 2011
    Thank you Airion for replying to me,
    There isnt any software that come with the unit because it was bundle with other country maps which i do not live in.
    There isnt any original SD card/sdmmc too. It's on Win CE 5.0
    Operation System Microsoft Windows CE.NET 5.0
    CPU TI TMS320DM355 400MHZ
    SDRAM 128MB
    NAND FLASH 128MB
    Map Storage Mode SD CARD
    GPS Model MTK3329
    Max Channels 66
    Sensitivity -165Dbm.
    Cold Start 35 S
    Warm Start 34 S
    Hot Start 1 S
    Max altitude 18000 M
    Max velocity 515 M/S
    GPS BOX Size 110 x 100 x 25 mm
    Antenna One
    I didnt wanted to unlock it, I just want to have my GPS to work. Trying the unlock was my last resort, but it didnt work anyway.
    I tried to install iGO and also Sygic which Eonon support says it should be working.
    Just couldnt go into the system and change *.exe path
    Hope there is more advise from the gurus to help me.
    Any help will be very appreciated.
    Thank you very much.
    Is there such thing as autorun? If it does, I believe I could set the autorun file to run the application which is on the device, no?
    3,132
    223
    Now ok.
    What is old software name and maps.
    Your device might have embedded or lock ROM for certain software to work.
    The solution is there.
    Oct 2011
    i think the Eonon was working with PolNav, I'll try that first
    I'll try your suggestions
    Thanks again
    Oct 2011
    Hi there,
    I have exactly the same unit and exactly the same problem!
    so I hope you have found a solution and of course that you would share the solution
    Thanks a lot for letting me know and thanks for everyone who helps us around
    Nov 2011
    hi i had the same problem and now i got it fixed!!!! and working with garmin
    instead pay for maps and the program in the eonon web page
    this one is fast and cheaper!!! and also you got it with garmin software that have
    almost all the maps!!!
    garmin software for car dvd gps eonon and other china players | eBay
    Jan 2012
    Quote Originally Posted by chrstation View Post
    Hey care to ellborate on what exactly you mean by Garmin ?
    which version ? where to find it ?
    map packs ?
    Jan 2012
    Ooops never mind... and I can't seem to find the edit button o.o
    Jan 2012
    Since I can't seem to find a edit, I have to post like this, my apologies moderators but I couldn't see any other solution.
    The link in the above post is dead.
    Is there ANYONE out there who can help me ?
