8th November 2011, 22:11
#1
GPS CROWN AGPS 2181
GOOD!
I needed help, gave this crown GPS AGPS 2181, no card, the menu says about the characteristics SOFTWARE VERSION: ND.0710201330M08, HARDWARE VERSION: MINI-VIEW 1.5-10xx, CAPACITANCE NAND FLASH: 64M.
The GPS does not bring anything, I see the residence flash memory and nothing brings it brings only the folder of Windows CE, but can not see that version. I would ask your help to solve this problem. I wanted to put the system and attached thereto tomtom map, How can I make this whole process and that it is running at 100%. Someone help me, some tutorial help or even if someone made publicly through msn help me. thank you
9th November 2011, 12:47
#2
Re: GPS CROWN AGPS 2181
Try here: http://gpsunderground.com/forum/tomt...y-problem.html
Go further into the thread for WinCE5/6 tomtom versions.
10th November 2011, 09:44
#3
I could not do anything, as the GPS has nothing, no card, it is best to do it again, and put everything to work. It has installed windows ce or windows mobile, you have nothing.
