Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 66
Like Tree8Likes
Thread: MEDION GoPal
  1. #11
    Jetrotte is offline Private
    Re: MEDION GoPal
    I can´t find the bottom for download ?
    Please answer thanks :-)
  2. #12
    172lover is offline Lance Corporal
    Re: MEDION GoPal
    Quote Originally Posted by Jetrotte View Post
    Click on the smiley faces man!
    Quote Originally Posted by Leinad View Post
    Map for Europe -Medion GoPal 6.0 - 2011.Q4
    Thank's a million man!
    A friend asked me to update his and I thought it would take me all night to find a link!
    Good old underground though!
  3. The Following User Says Thank You to 172lover For This Useful Post:
  4. #13
    Re: MEDION GoPal
    I have received cards from other ....
    I'm not interested to being directed to a payment page;-(
    I thought that GPSunderground was free for all :-)
  5. #14
    martin2410 is offline Corporal
    Aug 2012
    21
    Re: MEDION GoPal
    I have downloaded miopocket and copied the required files/folders to sd card. But when I put the sd card into the medion unit, nothing happens. I have tried soft restarting but that doesnt do anything. All I want to do is update the maps, so I followed the advice on here but it dont seem to work.
    Any help/advice please???
  6. #15
    gyany is offline Second Lieutenant
    Mar 2012
    A, A
    342
    Re: MEDION GoPal
    martin2410 What type of GoPal you own???
  7. #16
    Aug 2012
    21
    Re: MEDION GoPal
    Its the Medion Gopal PNA205
  8. #17
    Mar 2012
    A, A
    342
    Re: MEDION GoPal
    martin2410 https://rapidshare.com/files/3987302...ion_unlock.rar 1) Unzip and copy the sdcard 2) Start the device and when the original menu, enter sdcard Ciao
  9. #18
    Aug 2012
    21
    Re: MEDION GoPal
    thanks for the link but it just wont work in my sat nav. I dont seem to be able to access the sd card in the unit. Totally baffled. I think we'll just have to stick with the old maps.
  10. #19
    Mar 2012
    A, A
    342
    Re: MEDION GoPal
    martin2410 Make a copy of the flash device.Post it here and I will try to help..Backup without maps
  11. #20
    Aug 2012
    21
    Re: MEDION GoPal
    I guess I need to connect it to the pc and go into the sat navs folders. Ive done that and tried to copy the listings into this reply but I cant do that. I removed the sd card to view the sat nav folders. I now guess that I need to copy the downloaded files into the folders within the sat nav. Sorry if I sound a bit thick but I really havent got a clue with these things and Im so frightened of moving the wrong files in case the whole sat nav crashes. Ile list below the folders that are present.
    INSTALL
    MAP REGIONS
    MEDION
    SETTINGS
    NAVIGATION
    The next list is of files
    CLEAN FLASH
    CONFIG
    GPSPARA0
    GPSPARA1
    GPSPARA2
    GPSPARA3
    MENU
    MENUPROXY
    STARTED
    I hope this is of help.
    Thanks for your patience gyany
