8Likes
7th August 2012, 21:04
#21
Re: MEDION GoPal
I just need the folder NAVIGATION
8th August 2012, 12:21
#22
Re: MEDION GoPal
Ive tried to drag the navigation folder into this reply but that doesnt work (am I doing it right?). The list of folders in the navigation folder are listed below.
font
poi
roadicon
res
menu
poi-warner
resources
skin320x240
audio manager
help
pathfinder_orig
setting
dstcom02
mnavdce
pictureviewer
Thanks again for all your help. I did try a private message to you to try and send the folder to you, but that doesnt work either.
8th August 2012, 18:28
#23
Re: MEDION GoPal
just send me folder -mnavdce-1)you copy and paste in your computer.2)archive folder 3)Uploaded on rapidshare. 4)Copy link and post here
8th August 2012, 19:04
#24
8th August 2012, 19:06
#25
9th August 2012, 03:47
#26
Re: MEDION GoPal
martin2410 I'm sorry, but this is just an exe...I'm not sure that is what I serve..Send me MEDION folder and folder NAVIGATION...Do the same .. copy on your computer, archive, put it on rapidshare and post link..Another thing, make a backup of the entire flash..contains all memory and keep your computer safe
9th August 2012, 13:21
#27
10th August 2012, 02:01
#28
Re: MEDION GoPal
martin2410 In folder Medion is an executable..what's it called?
10th August 2012, 12:39
#29
Re: MEDION GoPal
there is 1 called cityguide.exe. Is that the 1 you are looking for?
10th August 2012, 14:05
#30
Re: MEDION GoPal
martin2410 Use Microsoft Active Sync,to make a full backup on flash.Can be repaired with a full backup
