Hi, i need maps for medion :/
Updated maps for Medion are hard to come by... better to install iGO, Navigon, or another navi software. It is fairly easy with most Medion units.
how is it possible to do it?
Did you have any link for us?
thanks
No step-by-steps instructions or links are really necessary... Download the latests version of MioPocket and follow the Medion specific instructions in the README file, it spells it out quite easily. After that install iGO or other GPS software just like any other PNA.
Gopal
Go to
I have just bought a medion pna205 to try and install tomtom on.I have copied the miopocket files to an SDcard and renamed the files as per the readme ,reformatted the card to fat32 but it will not work.when I put the sd card back in the reader two.registry files have been written to it so the card is being seen by the pna205 so does any one know what the problem may be? I also created a 2577 folder on a blank card with autorun.exe and the reg files were also written to it.
Thanks for any help
smud6ie
my dad have a medion go pal 4.1 me , and i search for maps updates , so i read this tread and the link are not work any more , can someone help me please ?
Map for Europe -Medion GoPal 6.0 - 2011.Q4
DACH (Germania, Austria, Elvetia, Liechtenstein) - Q4.2011 --->
Belgia + Luxemburg Q4.2011 --->
Croatia --->
Estonia, Latvia, Lithuania, Kaliningrad Q4.2011--->
Poland Q4.2011 --->
Czech Republic Q4.2011 --->
Denmark Q4.2011 --->
The Netherlands Q4.2011 --->
Romania Q4.2011 --->
Hungary Q4.2011 --->
Italy Q4.2011 --->
Sweden Q4.2011 --->
France Q4.2011 --->
Albania, Bosnia-Herzegovina, Bulgaria, Macedonia, Moldova, Slovakia, Slovenia Q4.2011 --->
Serbia, Montenegro Q4.2011 --->
Greece Q4.2011 --->
Belarus, Ukraine Q4.2011 --->
Spain Q4.2011 --->
United Kingdom, Ireland Q4.2011 --->
Norway Q4.2011 --->
Finland Q4.2011 --->
Portugal Q4.2011 --->
Turkey Q4.2011 --->
Special thanks to @dst !
