I have a Roadmate 1700 that just boots up to a screen that implies that I need to connect it to a computer. I figure it needs a firmware update. I downloaded content manager but I've been getting "server busy" for five days now and I cant update that way. Magellan CS says they can't provide me with a direct download of the update, so I come here asking if anyone can upload ANY version of the RM1700 update so I can continue using this GPS.
Thank you.
EDIT: If you've ever done an update to your 1700 then it's possible that you still have the update files on your computer. type %temp% into your run box and it'll take you to your temp folder. In that folder you should see a folder named "content manager" in that folder should be the update files.
