First you should go to the iGo section of this site, tons of info and downloads. Good luck my friend.
iGO GPS Systems
Can anyone help a complete newbie to all this !
I have some GPS Devices that i bought from a European Supplier a couple of years ago
they are running WINCE 5.0, they are TRAVELLER 550's
And currently running TELEATLAS (by smart2go) - to be honest the software is not great and i wanted to upgrade all 6 units to a better GPS software.
I have accquired igo8 for wince 5.0 ( i think) and wanted to know how to install this onto the systems?
Obviously the units have SD Cards - i have no idea where to start
any help would be great....
thanks
iGO GPS Systems
iGO GPS Systems
dseven A device connects to the computer and make a backup (a copy of the flash device).Archived copy, uploading to a sharing site and post link here.We'll help you install Igo.(no maps)
You mentioned Traveller, which stands for Sygic, and it is not bad at all if you have new maps on your unit.
I have Targa with Traveller on and I like it - as is - with new maps.
Hello!
I just got a Lark Freebird 50.3 GPS with WinCE 5.0, without navi software. I already downloaded Primo2 for WinCE, found the link on this forum. I copied everything to the SD Card, but it won't load up. I even created a shell.ini file containing "\SDMMC\Primo2\Primo2.exe", in the ResidentFlash directory. Note that my ResidentFlash folder was empty before, not sure if that's an issue.
Tried iGO8 as well, but even that didn't load up... Now I have no idea what to do. Any suggestions?
Did you manage to unlock wince
