13th August 2012, 01:34
#1
HELP!! D5103 Headunit cannot change GPS file path to microSD card to run iGO
When I go to change the path to my microSD card for the GPS software all I get as my options are [NANDFLASH] it doesn't show my microSD card or any of the folders on it as an option. I thought it might be a faulty microSD card but my headunit also has a microSD card slot for music and DVD's so I put it in that and it played movies and songs from the microSD card so its not a faulty card. I have also tried renaming my GPS software to the current path that is there and that didnt work.
Pictures of the problem:
Hopefully someone can help.
THANKS!
