Page 1 of 8 123 ... LastLast
Results 1 to 10 of 73
Thread: Please help regarding Blaupunkt lucca 3.5 maps ! plus i lost a post ???
    tomtombong is offline Private
    Hi there !
    Ok where to start, I first put a post in tomtom general discussion as my 1st question was regarding my tomtom, which i then found wouldnt acccomadate the euro maps i needed, so then i mentioned about a blaupunkt travel pilot lucca 3.5.
    I did have some replys, one particular reply gave a link that was rar'ed, something to do with the europe maps, thou it was a tiny tiny file, to which i questioned them on, and they said i needed jdownloader or cryptload ???? of which i have no knowledge, Im wondering now if its been removed because of most forums rules against illegal dowloads as such ? can anyone confirm this ? and if its all kosher can i have another link or and any info on getting it onto my gps, i need eastern europe for hungary on my lucca 3.5
    please oh pleasse goood peeps any help ???
    dseven likes this.
    Re: Please help regarding Blaupunkt lucca 3.5 maps ! plus i lost a post ???
    You are in the wrong section
    This is about car navigation systems
    You should go to the toys'R'us section
    r u taking the pee ? where is the toys r us section , or is that some form ov humour that gone over me head !
    An why has this post been moved, its reguarding a blaupunkt gps
    boooo hoooooo
    Essex UK
    209
    Quote Originally Posted by gazo View Post
    toys'R'us????
    You mean an opticians surly??
    I take it this
    http://gpsunderground.com/forum/showthread.php?1637-Blaupunkt-TravelPilot-Lucca-3.5-!-Hungary-Maps
    is the post you cant find, its even on the first page.
    The DLC file you refer to has to be opened in a program like jdownloader an its very easy to use.
    DLC files are a great way for encrypting links so they last longer.
    i bow to ur worldly knowledge !!! please forgive my iggnorance
    Feb 2012
    Oman
    Задать Вопрос
    Задать Вопрос , ZAFZFFAZPVFZ ,<a href="http://votebook.ru/">Задать Вопрос</a> , Votebook -
    Jan 2012
    United States
    free converting DVD to WMV software for iPhone?
    I am a Zune user while my kid only purchased an iPhone.
    I have a software which can transform DVD to WMV for my Zune, however the software cannot support creating MP4. Is there any freeware convert DVD to MP4? Or I need to transform DVD to WMV, then convert WMV to MP4 for iPhone?
    I only searched the site, however all shareware, just as dvd to wmv converter.
    Feb 2012
    Hungary
    Acne keloidalis nuchae
    When individuals believe of acne, they usually feel of an individual with an outbreak of red, inflamed pores on his or her face. Whilst this is the most common form, it's not the only kind of acne individuals could expertise.
    acne keloidalis nuchae
    Jan 2012
    United States
    fumar less ecigs reviews
    As i was going to mention cartridge mods, but after careful consideration I chose to talk about special still dripping wet. Following fussing together with quite a few wagon mods, one can find certain will attempt to work SO however , none can be very good. The next task is learning to direct generate that's the place you can be at some point regardless.
    Special still dripping wet, or maybe dripping can be leaking a number of drops regarding e-liquid for the atomizer together with vaping at bay. Uncomplicated huh? Most e-liquid include dropper wines that make the following astonishingly uncomplicated. Purely remove the for filler injections from your very own cartridge in addition to do it like a lips section. When you want to help drip, remove the cartridge and also splash a few sheds around the bridge from the atomizer. The actual connect is the raised center element covered with the bleak stainless steel mesh. Should your intent is just not spot on, usually do not fear. It won't injure anything.
    It takes only 2 to 3 falls that will completely humid your atomizer. If you happen to add more excessively you'll be able to myriad that atomizer, which leads to a good mouth complete with toasty e-liquid, the lot much less excitement than it all sounds. It is possible to acquire about 10 excellent puffs prior to deciding to discover any burnt metallic taste. Then you require additional liquefied. In time you will definitely get the particular hold of computer, and also realize once to add water just before you reach the period. Merely watch out for a lowering in heavy steam, not to mention flavour.
    A T-Tip coming from Superb Testosterone Development
    GoodProphets. com drip suggestions.
    Doing this might be doable from buying that which is often known as a drop rule. Super L Creation originated typically the generate tip, but still hands produces each of them. If you need to have a shot at 1 and need to give $20 for starterst there can be easily made knock-offs readily available much lower deals. Goodprophets. com contains them for the purpose of just $3. 50.
    If you happen to prefer the on the job process, or perhaps like myself personally are just cheap you can create your individual remedy. If you have had a clear round cartridge you can actually eliminate the circle end cap with all the problem getting a documents snap. Some people solely go over. You will realise an additional around drive which includes a ditch of which as well must be eradicated. You will come across the end of the fruit juice water tank. Consider a product pointed and cut the out there, and warm up a smallish nail plus use up a golf hole via it. It takes a comfortable strive, but you may splash throughout the pit.
    A further strategy is definitely actually simpler, although appears a little bit court rigged. Get rid of the rubber grip originating from a pencil as well as slip it all right covering the atomizer. You may implement via this, it insulates the lips belonging to the heat from the atomizer.
    It doesn't matter what strategy one have, dripping is, a smaller amount trouble, and far a reduced amount of sloppy as compared with it's possible you'll consider. E-cigarettes take even more planning than opening your pack and even lighting style a single together, nonetheless dripping can take a lot of in which bother right out of the formula. Seize a person's P V (personalized vaporizer, my own favorite name for the purpose of e-cigarette,) an individual's PCC (Very own Charging Condition,) and a container associated with e-liquid and you also are great for the day.
    Desire a lot more? Sign up higher than. We've so very much more in store available for you, as well as additional guides, testimonials, and some create your own private work!
    ecigs reviews
    Mar 2012
    Honduras
    generique viagra
    acheter viagra pharmacie - <a href=http://www.formspring.me/CiaraVonsoosten/q/236620853754735551#3118>viagra 100mg prix</a> , viagra generique | Formspring achat viagra france
    achat cialis generique - <a href=http://www.formspring.me/MeredithKucek/q/236620853628910518#5094>achat cialis generique</a> , cialis prix | Formspring achat cialis generique
    levitra generique - <a href=http://www.formspring.me/ArlenJodoin/q/236621103705884332#1348>acheter levitra</a> , levitra moins cher | Formspring vente levitra
    purchase amoxicillin - <a href=http://www.formspring.me/KeciaLataquin/q/179649411767376127#4264>buy amoxicillin online no prescription</a> , Amoxicillin Treat Chlamydia | Formspring amoxicillin 250mg
    buy isotretinoin online no prescription - <a href=http://www.formspring.me/DoraMolstad/q/178864407776881109#1719>purchase isotretinoin</a> , Buy Isotretinoin Online | Formspring buy isotretinoin online no prescription
    montelukast generic - <a href=http://www.formspring.me/LeesaPerrell/q/178847673552506179#2060>Montelukast</a> , Montelukast | Formspring montelukast generic
    priligy italia - <a href=http://www.formspring.me/CortneyMusilli/q/238193761060917686#6385>farmaco priligy</a> , priligy dapoxetina | Formspring priligy dapoxetina
    levitra farmaco - <a href=http://www.formspring.me/AkilahCotsis/q/238195020794962644#1388>prezzi levitra</a> , levitra generico forum | Formspring levitra generico online
    aldara price - <a href=http://www.formspring.me/KayceHavener/q/190497385888128756>aldara price</a> , Generic Aldara Cream | Formspring buy aldara cream
    lovegra in australia - <a href=http://www.formspring.me/MarciaCallegari/q/178849877126575873#6343>lovegra in australia</a> , Lovegra | Formspring buy lovegra
    buy kamagra in uk - <a href=http://www.formspring.me/LindseyEnriques/q/237830627745859267#6008>kamagra australia</a> , cheapest uk supplier kamagra | Formspring buy kamagra in uk
    order metronidazole online uk - <a href=http://www.formspring.me/RobVongsakda/q/179246146261128837#2436>metronidazole tablets 400mg uk</a> , Buy Metronidazole Uk | Formspring Metronidazole Uk
