Thread: Silvercrest pna-e3540t win ce 6.0 help please.
    oynak is offline Sergeant Major
    Belgium, Brussels.
    169
    102
    Hi all.
    I've a silvercrest pna-e3540T.
    I made a copy of the folder silvercrest on the device.
    I change it to test tomtom 7.9 win ce 5.0 it didn't work.
    I put again the original folder but I've now this message :
    Apllication Error.
    Application Traveller.exe
    encountered a serious
    error and must shut down.
    What Can I do please.
    it's not my device. :-(
    Belgium, Brussels.
    169
    102
    Re: Silvercrest pna-e3540t win ce 6.0 help please.
    nobody can help me??
    oynak,
    Did you already found a solution for this case? I wanna buy a Silvercrest pna-e3540 to put iGo software on it.
    Belgium, Brussels.
    169
    102
    hi sorry for the late reply.
    I found no solution for this.
    I put the original nav soft on it.
    DavorLister is offline Corporal
    Oct 2011
    Zagreb
    20
    Works for me with MioPocket Mini unlock. However, I'm having problems with resolution settings. I miss some resolution related files or something. The only thing I needed to fix was port/baud rate. That's it.
    Update: I fixed the resolution problem by editing the sys.txt file. Now it works just fine.
