Results 1 to 10 of 14
Thread: Bricked Binatone Carrera A350 stuck on start-up screen
    sug172 is offline Sergeant
    London
    41
    I have a binatone Carrera A350 stuck on the start up screen. Does anyone have the boot rom or can point me in the right direction to get it.
    AMG
  2. The Following User Says Thank You to sug172 For This Useful Post:
    London
    41
    Re: Bricked Binatone Carrera A350 stuck on start-up screen
    I managed to get a boot rom and I have now put tomtom on it but when it starts up it runs through the options and then I get the Activation failed screen, I press continue and voucher and I get an error message "Cannot find 'iexplore' (or one of it's components). make sure the path and filename are correct and all the required libraries are available"
    I have tried easy activator but it cannot find the device through active sync.
    the map is United_Kingdom_and_Republic_of_Ireland 845
    Can anyone help me.
    AMG
    I also have the X350 and thats exactly the same, anybody know where I can get the software? I suspect it's the memory card but without the software to try on another card I'm stuck. (it wont even load without the card in the slot)
    NoService is offline Lance Corporal
    That error message only appears when you have failed to use the keygen properly OR are using the incorrect meta
    NS
    Quote Originally Posted by sug172 View Post
    Can anyone help me.
    AMG
    London
    41
    I managed to do this, I used easyusetools and copied the files into the "insert meta" folder, activated them and then copied them back to the device via active sync. Works great.
    Jun 2011
    HELP needed, i have a binatone a350 and its stuck on the start up screen iv replaced the boot rom but still the same problem, but when i connected it to the pc and looked in the resident flash folder there seemed to be files missing so if any1 out there could give me a copy of there resident flash folder id be very greatfull, iv looked everywhere but with no joy for these files, but if you cant send me the files can you let me know what files should be in there as all there is at the moment are the gps files and nothing else?
    goldfishtrad is offline Corporal
    Jan 2012
    26
    I also have a Binatone A350 stuck on the start screen. Luckily I have access to a working Sat Nav and have copied the ROM using DiskRW. But how do I get them on the sat nav? I can't ssem to move it off the start screen - do I need to press buttons in a certain order?
    can anyone help?
    Jan 2012
    26
    I also have a Binatone A350 stuck on the start screen. Luckily I have access to a working A350 Sat Nav and have copied the ROM using DiskRW. But how do I get them on the bricked sat nav? I can't seem to move it off the start screen - do I need to press buttons in a certain order?
    can anyone help?
  10. #9
    hashima's Avatar
    hashima is offline Command Sergeant Major
    202
    54
    ROM Files for a Binatone A350
    Copy all 5 files onto a blank SD card.
    Put SD card in the Binatone A350.
    Switch on whilst holding down the sleep button, when the white screen appears release the sleep button and let it do its work.
    If all is OK the Binatone A350 should now boot normally.
    Attached Files Attached Files
  11. The Following User Says Thank You to hashima For This Useful Post:
  12. #10
    Jan 2012
    26
    Thanks Hashima - fixed and up and running now! Just to add, you need to hold the sleep button for about 30 seconds!
