Results 1 to 10 of 15
Thread: Magellan GPS Maps???
    mikekoz is offline Sergeant
    32
    I have a Magellan Maestro 4040 GPS that I would like to update. The device is 4-5 years old, and Magellan wants too much $$$ for the upgrade. They want more than the device is worth at this point. I see no discussion of Magellan on this forum. Is it not possible to get updates for the anywhere else?? Thank you
    Beartraxx33's Avatar
    Beartraxx33 is offline Sergeant First Class
    Ottawa, Canada
    117
    19
    Re: Magellan GPS Maps???
    here is a torrent list of updates...
    http://thepiratebay.org/search/magellan/0/99/0
    bjjfc's Avatar
    2,334
    327
    maybe u can check this site: Maps 4 Me - Free Maps for Magellan GPS
    32
    Thanks, but I have seen those posts in the torrent link you posted, and none of them work for the Maestro 4040. The other link you provided is only for the handheld Magellan topo devices. I am prob going to just give up on this one and chuck this thing!! Thanks anyway!
    gpswill is offline Corporal
    Outside the box
    28
    The best bet is to run a popular nav software like igo on it, that is what I did with my Maestro 3250 and I am very happy with the results.
    Sorry for offtopic, but i am new and can`t start a new topic (maybe an admin can help me and make this reply a new topic). Someone gave me a LongHorn GoGo 800 GPS sistem ( ), but it didn`t had the SD card in it. I`ve tried IGO8 on a SD card, but the device won`t start the navigation program - the igo8.exe was in the root of the sd card. When i click the navigation icon, nothing happens. Does anybody know if this device supports IGO and how the files/folders should look like on the SD card?
    Hello every body
    I have a similar situation I couldnt found the gps map for magellan "roadmate se4 2010 spring" is somebody know where I can found it please help me
    32
    Quote Originally Posted by kel8kel View Post
    I tried this, and the maps themselves worked. The problem I had was whan searching for POI's. Full addresses would not show, just numbers. I also would enter in known addresses that worked on the old maps, and it would give an unknown location error of some sort.
    32
    Interesting! How did you do this?
