Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: I am searching SONY-DVD "NVD-U13E" and "NVD-U13R"
    Mirkok's Avatar
    Mirkok is offline Lance Corporal
    Klodzko ; PL
    I am searching DVD:
    "NVD-U13E"
    for navi SONY: (NV-U93T/ U92T/ U73T/ U72T/ U71T)
    or
    NVD-U13R
    Does somebody have?
    eljoudi likes this.
    Luis is offline Sergeant
    Portugal
    49
    39
    Re: I am searching SONY-DVD "NVD-U13E" and "NVD-U13R"
    Hi
    I'm searching the same DVDs for Sony gps "NVD-U13E" and "NVD-U13R".
    If someone can help, my thanks
    Best Regards
    Hello to all,
    I am searching SONY NVD-U13E for NV-U93TC too.
    Best Regards
    Bert Impetigo is offline Lance Corporal
    Add me to the list, for the NV-U92T...
    Bert
    Zeppelin is offline Corporal
    18
    I searched and searched for this map without success; in the end as good ol' Sony have decided not to support these systems, I put igo8 on instead. Guys its easy and far far better.
    Good hunting anyway!
    Quote Originally Posted by Zeppelin View Post
    I'd happily do that, and in fact I've searched for how to do it - but the only instructions I can find are in POlish! Care to share with us exactly how to do it? :-)
    18
    This is a copy of instructions that I used... it really is very easy and the maps for ig0 are far better and up todate.
    Hope this helps!
    http://www.megaupload.com/?d=0VKITLS8 98 mb
    Warning, check the folder structure of your pna, if it is different, than it is a American device and that will not work.
    Looks for now that only European type will work.
    Unhide the folders in Windows Explorer.
    Rename the original nav-u.exe in folder Mounted Volume\Sony on the pna.
    Unzip the download file to for e.g. c:\Mounted Volume
    Copy c:\Mounted Volume to the pna with active sync.
    Reset the pna and look.
    You have to fill your self the content folder with your maps , voices etc.
    Only the new maps of Igo 8.3 will work!
    This is the structure of the folders:
    └───Mounted Volume
    >> Igo8
    >> ├───content
    >> │ ├───building
    │ │ ├───dem
    │ │ ├───lang
    │ │ ├───map
    │ │ ├───phoneme
    │ │ ├───poi
    │ │ ├───scheme
    │ │ ├───speedcam
    │ │ ├───texture
    │ │ ├───userdata
    │ │ └───voice
    │ ├───defaults
    │ └───license
    >> Sony
    >> nav-u
    If not working try,
    reset two times the pna
    remove save folder in IGo8 and reset, I will start with factory settings.
    With 71T you have to change in nav-u.mscr for finding the gps
    RunWait("\Mounted Volume\Sony\nav-u\ToolDevice.exe","off 18")
    RunWait("\Mounted Volume\Sony\nav-u\ToolDevice.exe","off 15")
    with
    RunWait("\Mounted Volume\Sony\nav-u\ToolDevice.exe","off 19")
    RunWait("\Mounted Volume\Sony\nav-u\ToolDevice.exe","off 17")
    and igo8 will find GPS
    For people who didn't make a backup,
    Backup Mounted Volume NV-U73T
    http://www.megaupload.com/?d=JGAZC29D
    NV-U93TC
    http://www.megaupload.com/?d=0FR5QSCE
    Nav-u50/70
    http://www.megaupload.com/?d=419M72E9
    Nav-u53
    http://www.megaupload.com/pt/?d=1BO3JYZO
    Nav-u73
    http://www.megaupload.com/pt/?d=JOIC2WF0
    Nav-u82
    http://www.megaupload.com/pt/?d=Q0773J9D
    Nav-u83
    http://www.megaupload.com/pt/?d=9LZ7ZGQV
    Look here also,
    http://webs.ono.com/escodaes/actuali...20y%20mapa.htm
    http://forum.gps24.pl/viewtopic.php?t=8949
    For other pna's to restore to Sony software again if you deleted all by accident, try this, thanks nukka
    1.
    Restore the folder Mounted Volume\Sony\Bitmap from one of mounted volumes backup, because this one is not in the Sony update.
    (The bitmaps are only different depending the size of the screen.)
    2.
    Update the last version of your pna with the software of Sony Website , http://support.sony-europe.com/eve/n...site=odw_en_GB
    3.
    Put a map in the mounted volume\Sony folder.
    Look here for aristidesfl his solution of Sony u71t + iGo8 + Standby Button + Back light sensor, but will
    work maybe also on other pna.
    http://forum.home.disney.go.com.org/...?f=277&t=66287
    Replace the nav-u.mscr contents with the following script:
    Copy("\Mounted Volume\Sony\nav-u\MortScript.exe","\Windows\MortScript.exe")
    Copy("\Mounted Volume\Sony\nav-u\PowerOn.mscr","\Windows\PowerOn.mscr")
    RunOnPowerOn ("\Windows\MortScript.exe","\Windows\PowerOn.mscr" )
    RunWait("\Mounted Volume\Sony\nav-u\ToolDevice.exe","off 19") #For t71 only
    RunWait("\Mounted Volume\Sony\nav-u\ToolDevice.exe","off 17") #For t71 only
    RunWait("\Mounted Volume\Sony\nav-u\ToolDevice.exe","on Serial")
    RegWriteDword ("HKCU", "ControlPanel\Volume", "Mute", 5)
    #This line removes the annoying beep that sony does when the screen is touched. If you like it just comment this line
    While (TRUE)
    Runwait ("\Mounted Volume\IGO8\iGO.exe")
    EndWhile
    Replace the PowerOn.mscr contents with the following script:
    Show ("iGO")
    #simple as that. This line brings the igo window to front making it visible.
    #It is possible that other versions of igo have different window's name so you need to change the line to Show ("igo8") or something like that if this one doesn't work. If you use other software you need to try the name of the software maybe.. but just if this one doesn't work.
    Thanks for that - I'll give it a go! Do you just use the iGo maps to be found hereabouts?
    Didn't have to - they weren't hidden
    Did that, though it's actually in folder Mounted Volume\Sony\ nav-u
    Did that
    Fails - not enough space on the device
    Some step(s) must be missing......
    18
    Ok, Ok Bert
    Been in your situation ......
    Have you tried re-setting twice
    Have you tried dumping maps of your nav-u ( keeping 1 map)
    did you make sure you cpiied via active -sync
    Have you seached for 'memory full' solutions?
    The instructions given have worked on many , many sonys-if you follow the instructions.
    If for example the hidden file instruction does'nt apply to you, it probably applied to 99% of other users.
    Use a bit of mouse and seach properly - I can still find a lot of ways to put igo8 on your system .... and its so, so easy
    You been given the spoon ...put somink on it.
    Though keep seaching on other threads for sony if you wish, he???!!!!
  1. 21st March 2012, 11:24
  2. 10th January 2012, 16:34
  3. NVD
    Refback This thread
    6th December 2011, 10:28
  4. Clix
    Refback This thread
    30th August 2011, 17:23
  5. 12th March 2011, 21:09
