Results 1 to 10 of 13
Thread: Bentley Continental GTC (2007)
    man20cese's Avatar
    man20cese is offline Staff Sergeant
    92
    Hello I have to update maps in a Bentley Continental GTC (year 2007). These are the images of the original broken disk and navi. I don't know this navi, what type of DVD it use? Audi...RNS-E...VDO?? I think it's a sort of MFD 2..
    Re: Bentley Continental GTC (2007)
    Try the VW MFD2 DVD version V7
    However to use the DVD the unit needs unlocking for which you may use the VW unlock cd
    man20cese's Avatar
    92
    Quote Originally Posted by gazo View Post
    Thanks Gazo! I suspected about a sort of MFD 2...I will try using unlock cd and v7 map.
    man20cese's Avatar
    92
    ...Another question Gazo: do you think I must try to update bentley system with the Wv firmware v.30 before to unlock?
    V30 is NEVER required. Not in a MFD2 and certainly not in a Bentley unit
    man20cese's Avatar
    92
    Hi gazo...I tried today the unlock disc and nothing appened...this unit isn't a MFD2!...so i tried a normal vdo cd and it worked. Now I must try a Bmw High 2011 DVD-R...What type of DVD should I try if high dvd from bmw doesn't work? This a vdo-siemens based system....
    It can then only be a High DVD that could work
    man20cese's Avatar
    92
    I can confirm this unit works with BMW High DVD 2011! Thanks for your help Gazo!
    if the BMW High DVD 2011 works, how about the BMW Navigation DVD Europe PROFESSIONAL 2011?
    i'm asking, because i need Romania.
    Thanks.
    If the High version works you have a High system
    What makes you think a Professional will work.? That is a completely different system
    There are no other discs that will work in your system except the CD's from the Non C-IQ series
