Thread: Help Needed
    GazzaMan68 is offline Private
    Wink Help Needed
    Hi, i dont know if any members can help me but i am trying to update my moms binatone A430 but they dont seem to do updates for it.i wondered if anyone has any idea how to update it or if i can run any other software on it as its not been updated for 2 years,I checked and its running tele atlas maps if thats any help..i heard that tomtom maps might work but i wanted to be sure as dont want to brick her unit and not sure if i need to change navcore etc..many thanks in advance.
    p.s great site
    gaz
    14acres10 is offline Sergeant
    30
    98
    Re: Help Needed
    hi gaz
    i converted an binatone a350 a while back and it runs igo8 on it, so there is plenty of up todate maps around on this site.
    Do not have the unit now.
    cheeres jim
  3. The Following User Says Thank You to 14acres10 For This Useful Post:
    goldfishtrad is offline Corporal
    Jan 2012
    26
    Re: Help Needed
    My Binatone A350 runs TomTom 7.9 just fine so I expect yours would too. Runs from a memory card so no need to mess with the software on the sat nav.
    There are lots of posts advising how to do this but let me know if you get stuck with it.
  5. The Following User Says Thank You to goldfishtrad For This Useful Post:
