this car have this CD Navigation
i will find a version of 2011
this car what CD need??
works any CD of another brand, for example BMW
THANKS gazo!!!!!
hi i dont suppose anyone jas a uk verion ,maps disc anything above 2009 would be appreciated
I don't suppose you have put in any effort al all to find the right disc
Just reading the above posts would have set you right
http://gpsunderground.com/forum/navt...-new-post.html
in fairness i have spent all bloody week looking as iam told one thing and then another iv looked at bmw high which dosnt work and such im looking at tele atlas discs or should it be a dvd
many thanks
Are you satisfied now or still confused?
Not much good (or smart) to try a DVD in a CD reader is it?
just picked car up no handbooks or navigation disc and as i didnt know what it took it was a case of asking the question but i did end up finding it 2011 with all other countrys aswell ill add link if anyione else wants it
if you have this car you should just pay for the update
