Thread: Road Angel
    mickflan is offline Private
    Road Angel
    Hi all,
    Just got a road angel navigator 7000 is there anywhere (apart from there website) that i can update the maps.
    Mick
    Re: Road Angel
    Hi Mick
    I have looked for a couple of years and not found any. However, you can run IGO or Amigo on it.
    You can put a 4Gb transcend SD (not SDHC) card in to hold all the maps.
    If you do chance upon any RA maps or speed camera updates, please post it on here.
    Aug 2011
    Re: Road Angel
    Hi - Just found this forum - I have access to all the maps for the Road Angel 7000 (Memory Map), both Explorer and Landranger, plus the software to run / view on a PC.
    The maps cover UK mainland but not Northern Ireland and I believe are dated 2005. Trouble is that they are total of 16.6 GB in size. I don't know what is the maximum size card thet the Road Agel can read from, so any assistance here would be wecome. I would also need a location to upload to, or maybe an alternative method.
    nn
  1. 12th July 2011, 18:08
