Page 2 of 19 FirstFirst 123412 ... LastLast
Results 11 to 20 of 190
Like Tree20Likes
Thread: Issue x8.5 on WinCE
  1. #11
    May 2011
    Question Any alternative way to install Papago X8 800x480 on Win CE 5.0?
    Hi all,
    is any way to install Papago X8 800x480 on Win CE 5.0 platform?
    tks for your help!
    cheers.
  2. #12
    bjjfc's Avatar
    2,161
    279
    Re: Any alternative way to install Papago X8 800x480 on Win CE 5.0?
    Quote Originally Posted by jim69 View Post
    Hi all,
    tks for your help!
    cheers.
    some members reported x8.5 can run on wince 5 but some said can't, you have to test yourself on your own device
  3. #13
    karnadi is offline Staff Sergeant
    Aug 2011
    61
    35
    Hi All,
    can someone send me a D/L for COM2 , BAUD 57600 + 4800 ?
    Thanks !!
  4. #14
    Dec 2011
    Re: Papago X8.5
    Hi, why my gps only have 4 icons in the main menu, travel guide is missing.. please help!! my gps info WinCE 6.0, RAM size 128mb, Resolution: 480x272
  5. #15
    Dec 2011
    Re: Issue x8.5 on WinCE
    I Need link to download Papago X8.5 wince 480x272 please ? thanks
  6. #16
    bjjfc's Avatar
    2,161
    279
    Quote Originally Posted by ajodotcom View Post
    read post #1 of Papago! X8.5 480x272 thread to request
    gpssion likes this.
  7. #17
    Jan 2012
    Dungun, Terengganu, Malaysia, Malaysia
    hi bro,
    need a lil help here. already download papago x8.5 + com port 7 file for my Lokatoo A1000 ( HD) . its 800 x 480 , com port 7
    now when i started the navi.exe no GPS signal detected. how do i exactly tell the papago software to use com port 7?
    Tq bro
  8. #18
    bjjfc's Avatar
    2,161
    279
    @kucau
    check ur pm
  9. #19
    Dec 2010
    hello fren.
    im using wayway device c/w papagox5, wince 6.0, . ive do backup on dataflash and sdmmc before replacing with papagox8.5 that ive download from here.
    my problem is when i want to activate it, only papago sound intro is came out without a picture. im reset the device also same.
    so im restoring old papago back. but it also same condition as before.
    what should i do? any help from sifoo..
    thanks and sorry for my english.
  10. #20
    bjjfc's Avatar
    2,161
    279
    @matjawa
    1) have you installed the correct version for your screen resolution (either 800x480 or 480x272)?
    2) have you copy the correct com exe from the com pack folder to mobilenavigator folder?
    3) have you delete all files in save folder?
    4) have you installed the correct x8.5 map into maps folder?
    5) have you execute to correct com exe?
  11. The Following User Says Thank You to bjjfc For This Useful Post:
