Page 1 of 19 12311 ... LastLast
Results 1 to 10 of 190
Like Tree19Likes
Thread: Issue x8.5 on WinCE
    zaifull is offline Private
    Issue x8.5 on WinCE
    How to make it full-screen?
    I just install a Papago X8.5 into my device.
    At the first time I have a problem while launching the software but finally i resolved the problem but the 2nd problem now, i just only can view a quarter on screen.
    Can somebody help me?
    k_wk, alex1118, thanawut85 and 1 others like this.
  2. The Following 4 Users Say Thank You to zaifull For This Useful Post:
    3,132
    223
    Re: Papago X8.5
    Which version did you install?
    alex1118 likes this.
    Re: Papago X8.5
    i suspected the resolution was not suitable for my device. I was installing the res. 800X480
    I think i should install the 480x272 one. Do you have the link for that?
    3,132
    223
    Re: Papago X8.5
    Delete everything in " SAVE " folder.
    Restarted application
    alex1118 and rusydi36 like this.
    Re: Papago X8.5
    was done that, still persist. it is about the resolution, nothing else i think. :-(
    3,132
    223
    Re: Papago X8.5
    Quote Originally Posted by zaifull View Post
    check your pm
    Re: Papago X8.5
    thank you very much. the problem is now completely settled. thank you for your kindness help.
    Nov 2011
    Issue x8.5 on WinCE
    Hi guys,
    I did as per the instruction but still got some problem. I am able to do routing and view and track GPS signal.
    1. Missing Junction View. I have also try with malfree map but still not working
    2. i got only 4 icons in the main menu - Destination, routing option, setting and exit.
    Is that correct? I saw my friend one it got video, demo and etc
    3. during routing, occasionally those background box will be missing. Those square box that cover the turn left and right sign.
    thanks
    Dan
  10. #9
    Nov 2011
    Re: Papago X8.5
    i have this problem too, do you mind share the method to change resolution?
  11. #10
    bjjfc's Avatar
    2,160
    279
    Re: Papago X8.5
    Quote Originally Posted by lkleong View Post
    check again your device spec, izzit 800x480 or 480x272?
    request again (click thanks) in the correct thread
  12. The Following 4 Users Say Thank You to bjjfc For This Useful Post:
