Thread: can papago work in android phone?
    jacksalous is offline Lance Corporal
    Aug 2011
    can somebody tell me how to install papago into android phone? thanks for help
    bjjfc's Avatar
    2,160
    279
    Re: can papago work in android phone?
    goto Papago x5 for android os thread to more info
    applle is offline Sergeant
    Feb 2012
    25
    3,132
    223
    Quote Originally Posted by applle View Post
    Install original apk into unit. Create directory in sd card. Copy maps and base files into directory.
    Replace the libpapago.so with crack libpapago.so
    Ensure that you have the correct crack for your country.
    Hong Kong, Indonesia, Southeast Asia & others - all are different
