Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 46
Thread: Papago! Philippines PRO
  1. #11
    diding2005 is offline Corporal
    15
    Re: Papago! Philippines PRO
    Hello Airion,
    I downloaded and copied the map to my Papago M7 and erased the chinese map, but it doesnt work when I try to run papago.
    is PPGM7 and PPGX5 not compatible with maps,thanks for your help
  2. #12
    3,132
    223
    Quote Originally Posted by diding2005 View Post
    Hello Airion,
    Know the difference between M and X versions
    They are not exchangeable.
  3. #13
    15
    Hi Airion,
    I have already extracted and copied X5 on my smartphone. also the philippines map
    I named the folder PPG X5 and copied the phil map to Maps folder,but when I click on papago.exe it runs until the music and then goes back to explorer,it wont fully start. Could you please tell me if there is still procedures I need to do to make it work. Thanks again in advance for your help(if there is a link in the forum detailing howto do it pls send me)
  4. #14
    3,132
    223
    Hi Airion,
    which and where did you download the phil map
  5. #15
    15
    i got it from this post > number 18th
    i read it now and maybe my fault is because it is for win ce and not for win mo?
    I have HTG Touch 3G with WinMo 6.1
    I tried to install MFM malaysia in it and it works ok so it is just the phil map that is not compatible. can u help me with this?thanks again
  6. #16
    3,132
    223
    You check your PM later
    My computer is defragmenting now
    After it finished. I upload for you.
  7. #17
    15
    Thanks again for the upload Airion.
    I deleted MFM malaysia map in the maps folder.
    download your file PHILIPPINES_R21 and extract the files,copied the files and paste it to Navi/Maps folder and start the program.
    when I start papago.exe I still get in to music part and then it goes back to explorer and would not fully start.
    I dont know what I am doing wrong??? it works with MFM Malaysia so the papago software is okay right?
    My unit is HTC Touch 3G Windows Mobile 6.1 with Papago X5 English installed (the one you sent me)
  8. #18
    15
    Hi Airion,
    I might be wrong here but maybe the problem is the map i downloaded is for WinCe with high resolution?
    Do you know where I can get Philippines map for PPGX5 Windows Mobile 6.1 with 240X320.Thanks again
  9. #19
    3,132
    223
    Hi Airion,
    Just rename your old mfm map header to R21_PHL.SCC and copied it to the map folder
  10. #20
    15
    Thank you very very much for your help and your patience with me. I finally got to make it work!!! Thanks again
