Results 1 to 10 of 15
Thread: help for Vietnam new map
    Apr 2011
    Hi Bro,
    I have some problem with new data map of Vietnam on my PND (buy from China).
    the link to download: http://www.vietmap.vn/downloads/maps...600_110331.zip
    this file is package include map data and navigator program (Papago X8)
    When I copy it to my PND, it run ok, but after about 5 minute, the screen turn to white screen, this problem still replay after reset the PND.
    As I know, this program or data may be lock by Vietmap (the supplier of GPS in VietNam), because there's lots of type of PND in VietNam and use data of Vietmap (free, but now cannot use anymore).
    So, pls help me find the problem or crack this to help me to use this data with my PND.
    Tks so much !
    3,134
    216
    Re: help for Vietnam new map
    Do you know how to use IDA Pro and UltraEdit
    phuongnt is offline Private
    Hi Airion,
    What to search for in IDA for this problem?
    3,134
    216
    This is the Vietmap exe for Com 1 4800 & Com 7 38400
    The edit address is
    Com = 0x5868ch
    Baud = 0x586a8h
    Multiupload.com - upload your files to multiple file hosting sites!
    Thanks for your files. But they still have problem that vn_maps mentioned above. The program can run properly in about 5 minutes then positions are randomly shifted to somewhere else.
    3,134
    216
    Quote Originally Posted by phuongnt View Post
    I run the maps without problems.
    Only matter is that I am not in Vietnam.
    So I can't tell. I have unlock the exe file.
    What unit did you installed to?
    Did the software ask for any code?
    Mine just run smoothly without any problem.
    Road and POI search is possible.
    The program runs smoothly without any problems, all functions work just fine. But after 5min of operation, the coordinates are shifted.
    Tks
    3,134
    216
    Do you meant there is an offset in position
    Yes, there is offset in position but ONLY after 5 minutes of proper operation. It is the new way of software lock mechanism.
    3,134
    216
    Well I can't give you any answer for that.
    It could be meant for specific device OR
    it needs a reg code to unlock.
    So no idea - will check when I am really free.
  1. 21st May 2011, 02:36
