Page 3 of 9 FirstFirst 12345 ... LastLast
Results 21 to 30 of 86
Thread: Problem with PAPAGO! X5SE
  1. #21
    techzone's Avatar
    techzone is offline Lieutenant
    375
    Re: Problem with PAPAGO! X5SE
    Try using the attached and make sure you are using the correct maps.
  2. #22
    techzone's Avatar
    375
    Quote Originally Posted by m4rc3l1n0 View Post
    can anyone give me the exe file also
    i tried com1,com2,com3,com4 and com7 but can't get a signal (i only have these 5 files)
    while igo working fine
    my screen resolution is 800x480
    or can anyone teach us how to edit the exe file with ultra edit?
    thanks guys
    Have you tried using this?
  3. #23
    hi everyone,
    i'm using double din dvd car player with gps(originally running Careland GPS Navi) but i would like to use Papago for malaysia.
    Any guide please?
    cheers
  4. #24
    techzone's Avatar
    375
    Quote Originally Posted by kernal65 View Post
    hi everyone,
    Any guide please?
    cheers
    What is your screen resolution?
  5. #25
    imperialrealcs is offline Private
    i need the exe file for
    port: 2
    baud rate : 57600
    screen: 480x272
    how do we actually edit ourself anyway?
    thx
  6. #26
    3,132
    223
    Quote Originally Posted by imperialrealcs View Post
    port: 2
    baud rate : 57600
    screen: 480x272
    thx
    Use this one - just copy and paste
  7. #27
    Hi Guys ,
    I`m Having a problem here with papago! X5SE
    Spec Of my Gps
    -China GPS
    -WinCE5
    -Port : 7
    -Baud 1200
    pls some one can give me, papago file with setting port 7 & baud 1200.
    Pls Help Thanks =)
  8. #28
    coolcola is offline Lance Corporal
    Cool Re: Problem with PAPAGO! X5SE
    need help for PPG X5SE
    -WinCE5
    -Port : 2
    -Baud 19200
    can anyone pm me the happy file?
    Thanx in advance!
  9. #29
    azli is offline Lance Corporal
    HI,
    Can anyone give me the papago x5 second edition exe file to work for my china pna:
    software : papago x5se
    my port : Com2
    baud: 9600
    Screen: 320x240
    thanks
  10. #30
    techzone's Avatar
    375
    Quote Originally Posted by azli View Post
    HI,
    my port : Com2
    baud: 9600
    Screen: 320x240
    thanks
    Here you go. Happy attached.
    Attachment 1351
