Page 9 of 9 FirstFirst ... 789
Results 81 to 86 of 86
Thread: Problem with PAPAGO! X5SE
  1. #81
    Dec 2011
    Re: Problem with PAPAGO! X5SE
    hi
    can help me to do 1? exe file?
    Port: COM1
    baudrate: 4800
    protocool: NMEA.
    10s 10s
    800 x 480
  2. #82
    bjjfc's Avatar
    2,171
    281
    Quote Originally Posted by desmondlcy View Post
    hi
    Port: COM1
    baudrate: 4800
    protocool: NMEA.
    10s 10s
    800 x 480
    check ur pm
  3. #83
    Jan 2011
    dear friend
    I need papagox5se exe files for com 7 baudrate 57600
    thx
  4. #84
    3,132
    223
    Quote Originally Posted by devilito View Post
    dear friend
    thx
    For which resolution?
  5. #85
    karnadi is offline Staff Sergeant
    Aug 2011
    66
    38
    Can i have file for com 2 baud 57600 res.480x272 - X5SE
    thanks a lot !!
  6. #86
    3,132
    223
    Quote Originally Posted by karnadi View Post
    thanks a lot !!
    C2 57600 - Download X5seC257600.exe from Sendspace.com - send big files the easy way
