Hi Guys ,
I`m Having a problem here with papago! X5SE
Spec Of my Gps
-China GPS
-WinCE6
-800x480
When i tried going into the program PAPAGO! The device will turn black screen and return to the desktop . i totally cannot enter the Program itself .
Pls Help Thanks =)
difficult to identify what went wrong , may came from the mismatch map , or may came from incomplete program you're install , may came from the unsupport display res ( normally PPG run with 480*272 , some program can be run on another res.)
I have downloaded the 800x480 PAPAGO! X5 Released by GPSTony Shouldnt be that problem Pls help
i downloaded it thereCode:http://gpsunderground.com/forum/showthread.php?877-Is-there-any-version-of-papago-for-800x480-wince6-pnd
hoho508,
will it possible for you to find out what is the com and baud of your device?
Com 1 or 2
Baud 4800 & 38400
Hopefully it`s helpful
Can i have the link to the dectector ? Thanks for the help guys hopefully can settle it asap =)
I didnt manage to use the Auto Detect But i checked my IGO Setting
Com port It`s using 1
Baud Rate 38400
This is the picture of my GPS Device . Hope it HelpCode:http://www.168smg.com.cn/pic/prod/E-018m.jpg
hoho508,
try this exe file and see the result.
