It may takes time for me to learn but not now as i need to use it urgently.
Anyone can provide me papagox5se with com port:3 and baud rate:9600? Many thanks....
Could you help for x5se with 480x272 resolution.
Com 7, baut 4800
No idea what it represents at all.
Change it - the exe file not work.
Not a job for amateur but cracker.
The exe file needs to be unlocked.
Needs to be unpacked by upx before any edition can be done.
It is not as simple as you think unless you are pro in utf8 and ascii codes.
If you want to be a cracker - do your homework.
Hi..
Anyone know how to change baud rate and com for X8.5?
