Results 1 to 8 of 8
Thread: How to define "Home" in RNEG?
    MegaShark is offline Corporal
    Jan 2011
    16
    I have defined the "home" location previously, but I forgot how.
    That is the option that allows to simply "Navigate Home" from any location.
    Any clues?
    I can, of course, define a new entry in the address book with this data, but that is not exactly the same.
    Thanks.
    super-cab is offline Lieutenant
    479
    118
    Re: How to define "Home" in RNEG?
    You must try to edit a choosen adress from the adressbook.
    You can save that one then as "home"
    Jan 2011
    16
    Thanks, that worked!
    Feb 2011
    hallo! I tried to do just that, but when I save, it remains in "waiting" for 2-3 min. and then must switch off to exit
    any ideas?
    Jul 2011
    Hi, I'm using the firmware v29 and I was unable to edit addressbook's entries (thus cannot set a location as HOME).
    My User's Manual states that there is "Edit Entry" option available after selecting the address book entry, but it is possible to calculate route only.
    There is no such menu entry in real device. Unless I'm missing something, can anyone help me with this?
    Of course I did my googling, but nothing useful came out.
    JaZ
    claudiobas's Avatar
    claudiobas is offline Staff Sergeant
    73
    102
    I dont' think that Rneg writes the phonebook on the SD, but...try to check the write protection switch on the SD... maybe...
    Jul 2011
    Recently I've added radards to the SD card, so I'm sure there is no write protection enabled.
    JaZ
    Jul 2011
    Problem solved. The option path which must be selected is very long and not documented. The trick is to select "Address Book Menu" option (above the address book entries) and then select the "Search" option. Next, you have to find your entry, select it, choose "Edit" option and there you can find "Set as Home" option. VERY "intuitive". ;-)
