Thread: which system in 406?
    can someone help please? trying to find maps for a system in a 53 plate 406 estate
    thanks for reading
    Re: which system in 406?
    Thanks for not telling the year of built
    I must therefore assume it is an almost antique car and the navigation system could be the Monochrome Siemens VDO system
    Siemens VDO Monochrome navigation
    thanks for the reply, but if u look again, u'll see that i stated 53 plate. ie second half of 2003
    hell is offline Lieutenant General
    1,409
    it is obvious for you and people from the UK maybe from ireland as well but not for anybody else how to convert number of plate to year of registration, but I am interested....
    regarding your problem: your system is probably the one mentioned by gazo (siemens mono system) which is unfortunatelly no longer actively supported, last release of maps for this piece of sh*t is the 7 cd set of europe from 2006-2007. I am not sure if it is available from somewhere to download and the mere 170 GBP that it sells for is definitely a rip-off....
    2003 406 can only have been equipped with the SVDO system for which I have already given the links
    TS did not even consider giving details of his navigation
    This question was answered and locked
