Results 1 to 9 of 9
Thread: Rneg My Way Maps 2009/2010
    41
    Thumbs up Rneg My Way Maps 2009/2010
  2. The Following 9 Users Say Thank You to xsarawrcchampions For This Useful Post:
    atfagent is offline Lance Corporal
    25
    Re: Rneg My Way Maps 2009/2010
    Bonjour,
    J'ai un C4 avec navidrive RT4 à voir !
    Est ce que cette carte est la bonne et comment l'installer ?
    Merci d'avance
    Quote Originally Posted by davbills View Post
    Bonjour,
    Merci d'avance
    Normalement non car le système WIP NAV et my way sont des systèmes compatibles uniquement entre eux et le rt4 et un autre système (c'est ce que j'ai lu sur le forum peugeot-com)
    etienne22's Avatar
    etienne22 is offline First Sergeant
    151
    2010-2011 maps ?
    etienne22's Avatar
    151
    Quote Originally Posted by chapter322 View Post
    This maps are on the sd card, cd or dvd ? I have Peugeot 308 2009 year, navi RNEG WIP. This maps are good for my car? Is there Poland ? Thanks
    The maps are for sale on SD card. The maps are for Citroën and Peugeot and Poland is on the SD card. It is Europe. I am waiting here on the RNEG 2010-2011 version (out this month)
    didu812 is offline Lance Corporal
    any news for RNEG 2010-2011 version ?
    jackdaniel is offline Private
    I copied the database-folder on the original sd-card, when i start the navi, it means "no software found" -> where i made the failure
    Now, i try to copie the original files on the card, i hope it will be function!
    Is there a system-file, which i can't copy?
  10. #9
    the card with the original files is ok an it functioned
    but how i can install the 2009-2010 maps? copy-paste in winodws didn't function
    Has anybody an answer?
