1. 1st May 2011
Threads 1 to 4 of 4
Forum: Rooting Sony phones
Root any model of sony with the help of this forum
» Normal Threads
    12th March 2015, 11:10 Go to last post
  1. How to Root the Sony Xperia Z1
    Started by veronicajackson91, 26th March 2014 09:43
    06, 2013, america, android, apps, ca, canada, cd, click, device, files, gps, high, phone, pro, problem, root, smartphone, software, sony, t, work, world, xperia, z1
    18th January 2015, 22:06 Go to last post
  2. How to Root the Sony Xperia J
    Started by veronicajackson91, 2nd April 2014 19:12
    2013, america, apps, blue, bootloader, ca, cd, click, device, extract, files, pc, phone, phones, root, rooting, series, smartphone, sony, system, united, western, work, xperia, xperia j
    2nd April 2014, 19:12 Go to last post
    4th March 2014, 22:12 Go to last post
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 15 replies or 150 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
