Results 1 to 10 of 20
Thread: Polnav v6.0.4 with MFM 20110915 maps
    3,132
    223
    For WinCE device v5/6 resolution - 320x240 . 480x272 & 800x400
    Countries - Singapore, Malaysia & Brunei
    Keygen included in software.
    Installation Notes -
    1) Copy software with maps into sdcard or internal flash.
    2) On start - run Polnav_kg.exe to run the map unlock.
    3) Then exit.
    4) Connect to PC via mass storage to Polnav folder.
    5) Find the " production text" generated by Polnav_kg
    6) Copy the text contents into the Device ID "registration entries" in MFM "Dual_English" folder using notepad or other
    7) Then save this " Device ID ".
    8) Restart software using Navigator.exe. (Not the Polnav_kg)
    Software -
    http://www.qooy.com/files/CF6ZXUJQ1T/PN_MFM.rar
    Icon - png format - resize as to your device
    QOOY - Pick your file host - Download - icon.rar
    For solution on Chinese or generic devices see post -
    Polnav Solution to Chinese GPS Devices
    Paid members - version with JCV in download area/other gps section
    Jul 2011
    Re: Polnav v6.0.4 with MFM 20110915 maps
    Dear Airion, is there any Indonesian map available for PolNav ? many thanks in advance, regards.
  3. The Following User Says Thank You to spursindonesia For This Useful Post:
    3,132
    223
    Quote Originally Posted by spursindonesia View Post
    Yes but I don't have it.
    Searching for it too
    calvinljh is offline Sergeant
    44
    Hi Airion,
    Any solution to fix Device ID
    Production txt = R000000006RE
    Thanks in advance
    3,132
    223
    Tried out success activating maps.
    See solution here -
  7. The Following User Says Thank You to Airion For This Useful Post:
  8. #6
    Jul 2011
    it this english version or chinese ?
  9. #7
    bjjfc's Avatar
    2,161
    279
    Quote Originally Posted by amnyh View Post
    language can be change in settings
  10. #8
    3,132
    223
    Quote Originally Posted by jeffkl View Post
    uploading.com so slow. further more it does not support resume. lost connection half way downloading for the 3rd time now.
    trying to download for the 4th time now, from 0%
    Use hotfile in post1 - just updated
  11. #9
    gigi7x is offline Private
    Feb 2011
    Are there also Italy and WEU maps? Where can I find them?
  12. #10
    3,132
    223
