Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 24
Thread: Polnav Solution to Chinese GPS Devices
  1. #11
    sctan41 is offline Corporal
    16
    Re: Polnav Solution to Chinese GPS Devices
    My also having this same error!!!
    [R0000000 06RE]
  2. #12
    andyteh is offline Sergeant
    48
    37
    Quote Originally Posted by sctan41 View Post
    [R0000000 06RE]
    inside the config folder, open DeviceId.ini with notepad edit
    [Key]
    WayToReadId=15
    save & done
  3. The Following 2 Users Say Thank You to andyteh For This Useful Post:
  4. #13
    16
    Many thanks, problem solved........
  5. #14
    pendi is offline Private
    Bro,
    have follow you intruction, and load indonesia map, but on polnav, to map is showing and to gps signal, something I miss?
    using chinese gps, com1, baud 4800, wince 6
    regards,
  6. #15
    musoh is offline Corporal
    Jan 2012
    20
    I installed PN-MFM, edit DeviceId.ini and run the app. But its in Chinese how to change to Eng. Please help!
  7. #16
    3,132
    223
    Change basic language setting of device to english.
    That will do.
  8. #17
    Jan 2012
    20
    Thanks for quick reply!
    But its in Chinese I dont know which button to select
    Edit..
    After scrolling finally I manage to change to Eng. Thanks anyway.
  9. #18
    alipark is offline Corporal
    Feb 2012
    16
    Hello there new maps for this browser in Europe
  10. #19
    George Brown is offline Sergeant
    Feb 2011
    48
    40
    Hi Airion.
    Please reupload this file to another Link.
  11. #20
    3,132
    223
    Quote Originally Posted by George Brown View Post
    Hi Airion.
    Device ID here
    QOOY - Pick your file host - Download - DeviceId.rar
  12. The Following User Says Thank You to Airion For This Useful Post:
