Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Polnav Solution to Chinese GPS Devices
  1. #21
    dseven is offline Private
    Aug 2011
    Re: Polnav Solution to Chinese GPS Devices
    Does this run on WINCE 5.0
  2. #22
    3,132
    223
    Yes will run, make all request for software in proper thread.
  3. #23
    ipin4u's Avatar
    ipin4u is offline Private
    Mar 2012
    Indonesia
    Quote Originally Posted by andyteh View Post
    inside the config folder, open DeviceId.ini with notepad edit
    [Key]
    WayToReadId=15
    save & done
    GREAT! Thanks, my problem also solved by your posting, thanks dude
  4. #24
    musoh is offline Corporal
    Jan 2012
    20
    I've just installed this app in my China X brand double din multimedia device with GPS res 800x480.
    It works fine with Sep MFM map, but not with Dec 11 update MFM map. Do I need to unlock it or how..
