Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Polnav Solution to Chinese GPS Devices
    3,132
    223
    The solution to solve device with " 000000000000000 " ID.
    1) Check your device settings / system info on sdmmc ID or sdcard ID code
    2) Copy and write a file " Device.txt " with ID code using text editor or notepad.
    3) Copy the saved txt file into the " root " directory and " config " directory.
    4) Replace the " DeviceID configuration settings " with the below.
    5) Start up with " Polnav_kg " to run unlock for map.
    6) Exit and connect to PC / Explorer via USB
    7) Copy details of " production text " into MFM map / folder / DeviceID.
    8) Restart software using Polnav.exe
    http://www.qooy.com/files/NLFM0LAI5L/DeviceId.rar
  2. The Following 7 Users Say Thank You to Airion For This Useful Post:
    oreyonebb is offline Private
    Oct 2011
    Re: Polnav Solution to Chinese GPS Devices
    how to check the device settings / system info on sdmmc ID or sdcard ID code?
    i don't understand !can teach me ma.....
    3,132
    223
    The device is yours. I can't check for you the information.
    Check the system info/about area for it.
    The instructions are up there.
    Oct 2011
    how to open the ''system info'' setting ?
    for window 7 sp1 !
    3,132
    223
    What is there to do with windows 7.
    It was meant for Chinese GPS devices
    For WM - no idea as I don't use WM
    Oct 2011
    got any tool can check the sdcard ID code????
    Oct 2011
    my device got this error
    can not get the valid device id,
    this device is probabiy not supported
    装置编号:[R0000000 06RE]
    HOW????
    3,132
    223
    Does your system info indicate or mention anything sdcard or sdmmc info
    or
    Post your device sys info screen.
    I see what I can do
  10. #9
    shahrulunder's Avatar
    shahrulunder is offline Corporal
    Oct 2011
    20
    i dont undrstand this step, can anyone tell me more detail about this step..
    tq..
  11. #10
    Sep 2011
    Dear Airion , The master!
    We've got a problem here with the Iranian map version of Polnav.
    We spent around 2 months figuring out how to generate a similar copy but up to now we are totally HELPLESS!
    I'd be more than grateful if you could help us. The issue is that , in addition to the map key , there is also one .DAT file inside the map folder which sounds to be encrypted too!
    I'm attaching a full zip copy of the software here. Could you please check it out when you found some free time and tell me the results?
    Thanks a million.
    Here is the link to the zip file : Polnav.rar
    Alimonz
