3rd October 2011, 10:57
#1
Polnav Thailand
Polnav Thailand
WinCE Resolution - 320x240 . 480x272 & 800x400
1) Copy software with maps into sdcard or internal flash.
2) On start - run Polnav_kg.exe to run the map unlock.
3) Then exit.
4) Connect to PC via mass storage to Polnav folder.
5) Find the " production text " generated by Polnav_kg
6) Copy the " text contents " into the Device ID " registration entries " Thailand " folder using notepad or other
7) Then save.
8) Restart software using Navigator.exe. (Not the Polnav_kg)
No keygen included.
http://www.qooy.com/files/FKEDBMOGBA/Poltha.rar
The Following User Says Thank You to Airion For This Useful Post:
26th March 2012, 09:08
#2
Re: Polnav Thailand
thanks , but need a new links pls ........
30th March 2012, 10:09
#3
