ce5/6
soft link xx replaced with tt
PolNav_6026 c/w keygen & jv & 3d & mfm 20111006 MySgBr map
hxxp://www.multiupload.com/WL89CHMPS5
After apply the key file, I still get:
Can not get the valid Device Id.
This device is probably not supported!
裝置編號: [R000 0000 06RE]
However, after pressing the OK button, everything looks just fine. Navigation works!
But, how can I remove the annoying message everytime I start the program ?
I have succesfully installed my polnav on my 2 din wince 5. however i got unregistered map error message. how do i rectify this because the navigation will only works for 1 hour and then it will shut down because unregistered map. Thanks
We already generate the ID device but still invalid key
