Thread: PolNav_6026 with key/kg/jv/3d Navteq & mfm 20111006 MySg map
    andyteh is offline Sergeant
    48
    37
    update:
    (1)new R7A0000006RC.key included for install in residentflash
    (2)pre configure com=1 baud=4800 (can adjust in menu)
    link : hxxp://www.multiupload.com/AIBUIUPL1Y
    replace xx with tt
  2. The Following 3 Users Say Thank You to andyteh For This Useful Post:
    Oct 2011
    Re: PolNav_6026 with key/kg/jv/3d Navteq & mfm 20111006 MySg map
    cannot see the JV or 3D building.
    How to make it work?
    48
    37
    Quote Originally Posted by yaryu83 View Post
    menu/setting/display -----enable/disable 3d landmark
    menu/setting/guidance-----select 3d heading up
    menu/setting/language ----- change map ( mfm or navteq )
    mfm only 3d ( map date 2011-10-06 )
    navteq jv & 3d ( map date 2011-07-01 )
