Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Like Tree8Likes
Thread: PolNav R6.0.28.p18 DATED 2012-02-29 WITH KEYGEN AND INSTRUCTION wince 5,6 , all res
  1. #11
    Jun 2011
    Re: Problem installing PolNav R6.0.28.p18
    Quote Originally Posted by George Brown View Post
    Does anyone here could help me how to install PolNav R6.0.28.p18?
    I'm using Indonesian map and I've tried several times but the map still doesn't appear on polnav soft. (the program works perfectly but without map)
    I have same the problem. I have followed the instruction in readme but there are no key file in PolNav_6028_P18 folder althought i run the polnav_kg.exe several time
    please advice
  2. #12
    Aug 2012
    Re: PolNav R6.0.28.p18 DATED 2012-02-29 WITH KEYGEN AND INSTRUCTION wince 5,6 , all r
    I've successfully install PolNav R6.0.28.p18 and crack !
    But, I've a problem.
    i have a map with 'Iran_Per.map'.
    I copied the files in the directory map.
    But with the implementation of the program will not read a map!
    how to add a custom map?
    please help me.
  3. #13
    Aug 2012
    i have same the problem, the program works perfectly but without map! how to add a map?
  4. #14
    3,132
    223
    This is Taiwanese version - mostly likely not to work with MFM maps without proper cracking.
    Tried it clean - to no avail local maps
  5. #15
    Nov 2012
    Can anyone links post ( Germany ) europe maps Easter and western for polnav. Please
  6. #16
    Oct 2012
    Hi user,
    I need only a new Germany.map (Q?-2012).
    Can somebody help?
    Thank you very much!
    The Biker
  7. #17
    Oct 2012
    Editing:
    The map must be from Navteq!
  8. #18
    observer320 is offline Lance Corporal
    Aug 2012
    Quote Originally Posted by andyteh View Post
    ( wince 5,6 , all resolution support )
    PolNav_6028_P18_2012-02-29.rar
    hxxp://www.mediafire.com/?jzr8h51098gu924
    Invalid or Deleted Files.
    Please re-upload
    Thanks in advance
