Page 3 of 9 FirstFirst 12345 ... LastLast
Results 21 to 30 of 81
Thread: Polnav Programs
  1. #21
    LJLJ is offline Corporal
    16
    Re: Polnav Programs
    I'm having trouble with polnav. When I try to make a route to somewhere, program start to calculate the route, but then it just freezes on somepoint (for example 59 %) and nothing happens. I have noticed it only when calculating >50 km routes. On shorter ones haven't noticed. I have tried polnav versions 5.8, 6.08 and 6.20 with scandinavian maps from the other thread of this forum. I'm running polnav on wince6.0 car unit. Any fix for this problem? I would appreciate if someone could help.
  2. #22
    dpmiller is offline Lance Corporal
    Re: Polnav Programs
    A memory issue perhaps? Does it route successfully on a clean reboot?
  3. #23
    16
    Re: Polnav Programs
    no it does not route succesfully. And i don't think its a memory problem, because igo8 and igo primo and lots of others are running... I would like to use this, because this is very fast loading.
  4. #24
    mylnym is offline Sergeant
    30
    Re: Polnav Programs
    See posts 451 and 455 at for a discussion on routing.
  5. #25
    Re: Polnav Programs
    I need help. I have 7 inch GPS and this program stay on the 50% of the screen. How I can make the full?
  6. #26
    Re: Polnav Programs
    I am looking for east and central europe maps 2010 for POLNAV cosmicnavigation ! Anybody have idea where to get it ?
  7. #27
    Re: Polnav Programs
    I cannot find walek75's keygen anywhere, could someone please give me a link to the thread or keygen itself? Ive tried searching
  8. #28
    30
    Re: Polnav Programs
    Quote Originally Posted by wbarfels View Post
    Check the second post of this thread.
  9. #29
    canuck's Avatar
    canuck is offline Private
    Re: Polnav Programs
    Here is ARM V6.0.22
    And the latest Polnav executable, version 6.0.24
    Polnav 6.0.24 with icon
  10. #30
    bosanci28's Avatar
    bosanci28 is offline Corporal
    Jan 2011
    usa
    26
    Re: Polnav Programs
    hello,
    i did some search on this forum,about "polnav" and i find this tread...
    anyway...
    i have purchased a car gps unit from here
    that i think you can use any maps,like route66 and others,
    right now in the menu i found some info something about : navteq2007q4 date 2008/02/26 mapcode usa_west@2007
    but when i went into the 2gb microsd card to see the contents ,somewhere in "about" file and i open and it say:
    [Info]
    AppName=PolNav Car Navigator
    Copyright=DualStar
    so that means that the car dash gps is running under polnav maps and software?
    it has 800x480 resolution
    win ce 6.0
    how do i update this maps? for usa,west coast.,
    and the gps unit come with some demo that does not expires,they said,,but for some reason i see the curson and streets names,,but no building,highway lines...and others ,dont know whats going on...
    can someone clarify what is my next step to get the 2010 maps or maybe put igo primo maps,i think they are better...
    please let me know!
    thank you
