I'm starting this thread as a collector for Polnav programs.
This is ARM V5.04.
http://www.4shared.com/file/_jSyBkJI/Polnav504.html
Great idea for a thread! Should be a good one.
This might be useful at some point in getting PolNav to work.
walek75 provided a keygen for Version 6 on another forum.
http://rapidshare.com/files/345768954/Finean_KG.zip
1. copy exe to main Finean (Polnav) directory
2. copy Rxxxxxxxxxx.key to map folder and rename it to Device ID
3. execute Polnav_kg.exe
4. after exiting from Finean_kg in main directory should be file .key
5. edit it (remove duplicated lines)
6. kopy edited .key to map and run original (no cracked) polnav exe
Another PolNav program. This is ARM V6.0.8 with ISTTS, but no TMC. It is also known as the Brivi version. Use walek75's keygen to register your maps.
http://rapidshare.com/files/38703952...TTS_No_TMC.rar
This is also ARM V6.0.8 but with a TMC component (for Taiwan and Germany only) and no ISTTS. A different interface than the version posted above.
http://rapidshare.com/files/38732243...TMC_No_TTS.rar
Add the ISTTS folder and the executable from the version above to get TTS.
The only MIPS version I know of is V5.5.4
Since I don't have a MIPS device, I don't know if TTS or TMC can be added. It's unlikely (probably impossible) that walek75's keygen will register maps.
http://rapidshare.com/files/387042036/PolNav-MIPS.rar
Here is ARM V5.8.22
Probably superseded by the V6 releases? It has TTS.
http://www.4shared.com/file/nl8TN-ML...822_ISTTS.html
A V6 manual is now available here:-
Another forum refers to other versions of Polnav...
6.0.18
6.0.80
6.0.20
Anyone have either/all of them and can upload please?
nm, dono how it happened but it's working again.
