Results 1 to 10 of 16
Thread: NAV System DVD for Nissan
    Hi all! In my Nissan 350Z, I have a GPS that is not up to date (2006 European maps).I Already downloaded and burnt those 2 ISO files: Carminat Navigation Communication - Western Europe v29 dvd - Maps Nissan 2010 for xanavi X6. But does not work. There is only a "Checking DVD..." message on the display.
    I was wondering if somebody here will be so kind to upload such a DVD in 7.x version (2010 or 2009), like this disk:http://www.350z-tech.com/zwiki/TSB_0...sc_Information
    Or maybe provide me a link if it was already posted
    Anyway, thanks a lot
    Re: NAV System DVD for Nissan
    http://linksave.in/17667112684bedbc3699cd6
    Burn slowly to prime quality DVD9
    Renault/Nissan V29 X7 2010
    Thank you gazo for the link you provided. Unfortunately, it doesn't work, and still have the same message on the display.
    Did I made something wrong?
    I used CD Burner XP to burn the ISO on a INTENSO DVD+R DL @ 4X speed
    The only programs that I know of that will burn the DVD correctly are Imgburn and Alcohol. No other program will do the job
    Use only Verbatim and Philips DVD9
    Quote Originally Posted by gazo View Post
    Thanks a lot Gazo, works perfectly now ! (Used Verbatim DVD9 & Imgburn)
    Andy D40 is offline Private
    Having problems with part 13 will not download, can anyone help
    Quote Originally Posted by Andy D40 View Post
    I have just checked and there is nothing wrong with part 13
    I tried again and still having problems i use the free user link then wait for 120 seconds when the dowload link comes up i click on it and it says the download session has expired. All the other parts work i am just missing this one HELP anyone
    Take a subscription rather than bothering others with a problem that is solely yours it seems
    Hi. I have a Nissan Murano 2006 with Xanavi X6 version. I downloaded the Carminat Navigation Communication - Western Europe v29 dvd - Maps Nissan 2010 for xanavi X6 and works correctly. The problem is that I live in The Canary Islands but these doesn´t appear on maps so I can´t use the nav. Does anyone has an idea to fix my problem? Is it possible to update the x6 version to x7?Thank you for your reply.
