Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: What System do I have?
    Slicker is offline Corporal
    15
    I am a little confused with all the different Carminat systems and I am not sure which one I have?
    I have a Laguna 3 (58 plate) sport tourer dynamique. The CD that came with the car is V27 CNI2, but I also have the bluetooth. Does this mean I have a CNI2 or a CB-CD? Or are these just the same thing?
    Paul
    hell is offline Lieutenant General
    1,410
    Re: What System do I have?
    Quote Originally Posted by Slicker View Post
    Paul
    it is a Carminat Bluetooth CD (CBCD), it just uses the same disc as Carminat Navigation Informee 2 (CNI2).
    15
    Hi, thanks for the info.
    another question - I have heard there is an engineer type menu that can be accessed with code 4112 and that tells you version of SW and maps... Is that correct? I can't find how to get into that menu?
    From what I have read, it seems to be navigation setting and then enter the code. I can't get this to work and if I try and enter the code it just changed the radio?
    Any thoughts?
    thanks
    1,410
    Any thoughts?
    thanks
    well your information is more or less accurate. to be short there is no service menu in CBCD. in CNI1 and CNI2 and other VDO MSxxxx systems you can access the system service menu from the settings, it has a dedicated entry to enter the code (4112 in renault systems and 6330 in VDO Dayton systems) , but there is NO such menu in CBCD. I am absoloutly sure because I have just finished the hungarian translation of this unit a few days ago and no related text was found in the menu text.
    by the way the only way to get information about the current software version ('s date) is to insert a publically never released software update disc, on the other hand if you insert a map cd the system is going to tell you both the inserted and currently instelled (if any) map's name and version, eventually it will warn you if you would like to install an older version of the same map, so it is a kinda smart.
    15
    right so that makes sense. I have a CD with the map's so i assume thats the one that is loaded. Is the system software updateable as well then?
    All this may be true, however in the SW 2.18 I notice the following entries:
    Please enter PIN code to access the system.
    Please enter the current standby PIN code
    Please enter a new standby select a system function.
    You have given a wrong code.
    Code
    Monitor config.
    16:9 Monitor
    4:3 Monitor
    Sync in green
    No Sync in green
    Read I/O state
    Set I/O state
    TMC Diagnostic
    Demo
    To start a demo you need a home and a work address in the address book!
    To start a demo you need a home distinct from the work address!
    This would indicate there is a Diagnostic menu only accessible with a PIN code
    Although the software resembles the software of some of the VDODayton 5XXX models there is also ample proof it is meant solely for the CNI 2
    15
    hmm,, that has confused me again then..
    what is the link between the VDODayton and the CB-CD? Is it the same hardware?
    I assume the sytem software is updateable then?
    Do not misunderstand me! I was only reacting to hell's statement there is "no service menu"
    Of course the SW is updateable.
    No one has even suggested it it would not be possible
    But the SW update has no relation to an engineering menu
    15
    ah, ok..
    I was only asking about the SW as I wonder if newer versions will have full post code entry and better alternate route selections
    The data in CARINDB, the main database on the cd only includes the postal codes in numerics only. There will never be full oostal code search since there are countires where also letters are used.
    A separate Postal code finder is necessary with the map software, not the system software
